Use PIM Debugging Commands
Use Protocol Independent Multicast (PIM) traces to aid in PIM troubleshooting.
    enable
    configure terminal
  2. Start debug trace message output:
    debug ip pim pimdbgtrace
  3. Stop debug trace message output:
    no debug ip pim pimdbgtrace
    default debug ip pim pimdbgtrace
  4. Configure the system to display trace messages forwarded by the device:
    debug ip pim send-dbg-trace
  5. Stop the system from displaying trace messages forwarded by the device:
    no debug ip pim send-dbg-trace
    default debug ip pim send-dbg-trace
  6. Configure the system to display trace messages received by the device:
    debug ip pim rcv-dbg-trace
  7. Stop the system from displaying trace messages received by the device:
    no debug ip pim rcv-dbg-trace
    default debug ip pim rcv-dbg-trace
  8. Configure the system to display hello messages forwarded or received by the device:
    debug ip pim hello
  9. Stop the system from displaying hello messages forwarded or received by the device:
    no debug ip pim hello
    default debug ip pim hello
  10. Configure the system to display and log debug trace messages:
    debug ip pim pimdbglog
  11. Stop the system from displaying and logging debug trace messages:
    no debug ip pim pimdbglog
    default debug ip pim pimdbglog
  12. Configure the system to display register messages forwarded or received by the device:
    debug ip pim register
  13. Stop the system from displaying register messages forwarded or received by the device:
    no debug ip pim register
    default debug ip pim register
  14. Configure the system to display debug trace messages after an enabled message type, for example, hello or register, is received from a specific sender IP address:
    debug ip pim source {A.B.C.D}
The following table defines parameters for the debug ip pim command.
Variable
Value
assert
Displays the assert debug traces. The default is false (disabled).
bstrap
Displays bootstrap debug traces. The default is false (disabled).
group {A.B.C.D}
Displays debug traces from a specific group IP address. The default is 0.0.0.0 (disabled).
hello
Displays hello debug traces. The default is false (disabled).
joinprune
Displays join and prune debug traces. The default is false (disabled).
pimdbglog
Logs debug traces. The default is false (disabled).
pimdbgtrace
Displays PIM debug traces. The default is false (disabled).
rcv-dbg-trace
Displays trace messages received by the switch. The default is false (disabled).
register
If enabled, the system displays register debug traces. The default is false (disabled).
regstop
Displays register stop debug traces. The default is false (disabled).
rp-adv
Displays RP advertisement debug traces. The default is false (disabled).
send-dbg-trace
Displays trace messages forwarded by the switch. The default is false (disabled).
source {A.B.C.D}
Displays debug traces from a specific source IP address. The default is 0.0.0.0 (disabled).
